Hey guys, I have an 18' Caravelle with an OMC 3.0 with cobra outdrive. I've noticed the last few times I've taken the boat out that the power is diminishing. It's never had enough power in my opinion since I bought it last year. I thought it was maybe a dirty bottom, fuel filter, plugs, etc but all were fine. Then I decided to check the timing today and it was set to about 3 degrees BTDC. From what I read on a tech article my engine should be set at 10 BTDC. I followed the procedure and advanced the timing about 5 degrees to 8 degrees to start off and wow what a difference. My hole shot was substantially improved.
Before I go and advance it to 10, I wanted to check with you guys to be sure 10 is correct, and also to ask how far I can advance the timing if I always run 93 octane?
