timing question
laker925
If your timing is 1 tooth off-76 merc 4 cyl -what will you notice different than if exact?(forward one tooth /and backward one tooth)
Chris1956
Re: timing question
Laker, You will find it difficult to adjust carb/timing synchronization. it will be difficult to make idle carb. pickup adjustment.
laker925
Re: timing question
Please just tell me the symptoms --im not asking on repair..<br />-and i am speaking of the timing belt -one tooth too far or one tooth back--<br /> what are the symptoms-(example)a hair faster advancing if forward one notch? /slower if back one?<br />It is tottaly repaired properly and I wanted to know if -1 tooth what symptoms appear..
Silvertip
Re: timing question
This is a relationship issue and it depends not on the belt but whether you are talking about the crankshaft or distributor being one tooth off. If the crank is one tooth advanced in relation to the distributor, the timing is retarded and you will likely notice decreased performance -- unless you readjusted the timing to compensate. If the crank is one tooth retarded, the timing is advanced and detonation and possible engine damage can occur unless the timing is adjusted to compensate. Timing is always relative to crankshaft position so the belt has nothing to do with it. Its the position of the distributor relative to the crank position.
timmathis
Re: timing question
Don't go over 21 max timeng. It can be deadly!
laker925
Re: timing question
By using the "one tooth off" I meant one degree on the timing reading..<br />-so if it is 20 what will it do?
timmathis
Re: timing question
If it will run good at 20. It should be ok. on mine the manual said to set it at 23 max advance. But with todays gas go no more than 21 max advance. Or it can spark-knock and eat your pistons!
Clams Canino
Re: timing question
Just make sure the belt is on right and time it for 21. Real simple and safe.<br /><br />-W
laker925
Re: timing question
I wonder if thats what just happened...does it happen all in one shot or gradually?<br />I just had a paid profession reset it all and now the #1 cyl is dead-after 1 run(but of coarse it was nothing on their part)....
laker925
Re: timing question
And what does it do when the reed is going out or how can you tell if it is?<br />And when the lower tube that lubes the lower bearings disconnects what will it cause /damage?
jheron
Re: timing question
That tube lubes the top bearing ... If #1 is dead you are going to have to tear her down, so replace the bearings then.<br />Jon
