need timing specs on '84 merc 150 v-6. thanks.
D dadgummit Petty Officer 3rd Class Joined Dec 30, 2006 Messages 96 Aug 18, 2007 #1 need timing specs on '84 merc 150 v-6. thanks.
Barnacle_Bill Admiral Joined Feb 8, 2004 Messages 6,469 Aug 18, 2007 #2 Re: timing specs on '84 merc 150 v-6 Primary is 11? ATDC Max is 18? BTDC at cranking speed to obtain 16? at WOT per Seloc manual
D dadgummit Petty Officer 3rd Class Joined Dec 30, 2006 Messages 96 Aug 18, 2007 #3 Re: timing specs on '84 merc 150 v-6 thanks bhile. should I bump the max advance up a little? there are no advance modules on this motor.
Barnacle_Bill Admiral Joined Feb 8, 2004 Messages 6,469 Aug 18, 2007 #4 Re: timing specs on '84 merc 150 v-6 dadgummit said: thanks bhile. should I bump the max advance up a little? there are no advance modules on this motor. Click to expand... Seems like I read somewhere it should be a little higher with those modules removed but I can remember where I seen it. Hopefully someone else will jump in here.
D dadgummit Petty Officer 3rd Class Joined Dec 30, 2006 Messages 96 Aug 20, 2007 #5 Re: timing specs on '84 merc 150 v-6 I think I can safely add 2-4* to the max timing in place of the advance module. Anyone agree? thanks
