timming issue
henryrock
hi all here i have is 105hp Chrysler like to no what is timing for them on fly wheel has 10 on rule has -4 -2 which do i use get timing magneto ignition 11
Frank Acampora
Re: timming issue
Timing is 30 degrees before Top Dead Center at Wide Open Throttle. To get this, with the engine running at WOT and someone else driving the boat, set the 36 degree mark on the flywheel to the -4 line on the pointer. Use the screw between the two black plastic blocks to set timing. Shut the engine and make an adjustment then restart and test with the light. Repeat until timing is correct. Do it this way because there is a real danger of getting a finger or hand into the flywheel if done while running.
henryrock
Re: timming issue
hi frank on fly wheel only has 10 no 316 marking can i use 10 instead
Frank Acampora
Re: timming issue
No. It is not 10, it is the way Chrysler stamped "0" degrees. The line that looks like a 1 is actually the "0" degree line. If you have no 36 degree mark, you can count the number of teeth in the flywheel and divide into 360. This gives you the number of degrees per tooth. Count out the correct number of teeth to the left of the "0" line to mark 30 degrees. Now, when timing, set that 30 degree mark to the large line on the pointer.
