timming question please hellp
DAN M VAGOS
hi all how can i check the timing i have a force 50 1989 it has 125 and 130psi and the carb is clean and it seems to have fuel. the engine just seems like it should have more power. timming is the last thing i have not checked.
bentle
Re: timming question please hellp
What rpms r u getting at wot. Also what size prop are you running? Timing would most likely only be out of adjustment if you have already tried to set it without any luck.
jerryjerry05
Don't mess with the timing.If it's running good then do what bentle recomends.
Need a tach and go for a ride, take some readings.Post them.RPM's at WOT.Size prop?
Top of the Force section.1st post is a link by FrankA called a linc and sinc.Do that and post your results.J
