Tinny hull repair
san dimas
OK guys. I checked the rivits and seams on my 14' Valco using water in the boat (not too much water). I found 5 or 6 leaky rivits and 2 or 3 seams that are leaking. I also found a crack in the bottom about 1/2" long that leaks the most. The gluvit I ordered from Iboats should be here on monday. I hope this will solve my leak problems. It was leaking about a gallon in 2 hours. I'm going fishing up in the Sierra mountains next month and don't want to be standing in a wet boat:)
jigngrub
Re: Tinny hull repair
Before you Gluvit you should have the crack welded or patch it yourself and replace or rebuck the leaky rivets.
boatnut74
Also be sure to drill some small holes on each end of that crack to keep it from getting any bigger. If you get it cleaned up a welding shop may not even charge you for it.
san dimas
Using gluvit
Using gluvit
Can I use Gluvit on the outside of my leaky rivets and seams or does it need to go on the inside. 14' Valco.
Thanks.
Woodonglass
Re: Using gluvit
Re: Using gluvit
Usually on the inside but have seen/heard of people doing both. No UV protection so do what needs to be done.
san dimas
Re: Using gluvit
Re: Using gluvit
Thanks woodonglass. I've been told to buck the rivets before applying Gluvit. What's the best way to do this? Thanks.
Woodonglass
Re: Using gluvit
Re: Using gluvit
You and a friend. 2 lb sledge hammer used as the "Back Up" Regular Hammer on the inside as the "Hitter" Couple a Whacks and they should tighten up, or so I'm told. I'm not a tinner. Just passing on what I've read here on the forum.
andyrmilwaukee
Re: Using gluvit
Re: Using gluvit
I have fixed up two old aluminum fishing boats, not the fancy kind but the kind with bench seats. rebucking rivits is really easy and is just like woodonglass said, I applied the gluvit on the inside after rebucking and then painted to protect form UV rays. If I understand correctly the inside is the proper way to do it, but I am far from an expert.
san dimas
Another aluminum hull repair question
Hello everyone.
I have six rivets that leak on my 1979 aluminum Valco. I have bucked the rivets and was getting ready to to put Gluvit on them. Some of the rivets go up under the seats and I don't want to take the seats out to get to the rivet, so I would have to apply the Gluvit to the outside only which doesn't seam optimum. I found some closed-end rivets from McMaster-Carr. If I drill out the leaking rivets from the outside and install the new rivets with a dab of Gluvit on them would this be the best thing to do? Also, I have some leaks on the port side seam below the water level. I have the same problem with the seam on the inside being hidden by the seat bench so I could only seal the outside. I could drill out these rivets also and do as I said before but I don't know if this will seal the seam. Any input from you guys would be greatly appreciated! Thanks.
Bob_VT
Re: Another aluminum hull repair question
I have consolidated and merged your repair threads to make things easier to follow. You can continue to add to this one ;)
san dimas
Thanks Bob VT. I wasn't sure how the forum works. Now I know:)
jigngrub
You can grind or drill the rivets holding your benches in and remove them, then use the closed end blind rivets to reinstall them for a better job.
You could probably dip the end of the rivet in Gluvit and then install it, may not be as good as a thicker/quicker setting epoxy... but will be better than nothing.
It doesn't take long to get a "feel" for the blind rivets, and once you do you'll wonder why you weren't using them before... they really do come in very handy when you own a riveted boat.
san dimas
Took boat out yesterday and no leaks after a little welding and Gluvit. Thanks to you all for your help.
