SSTKO81
- Jun 1, 2009
- 348
Had my 140 running on the muffs today and found the the center head bolt on manifold side has tiny little oil bubbles showing up around it. -couldnt tell if it was a leak or boiling off oil that was already there. Also noticed some tiny little bubbles showing up around manifold gasket. All bolt torque specs are spot on. I'm going to run a compression test, but has this happened to anyone else?
