tinytach
rolmops
Will a tinytach that works on a 2 cylinder 2 stroke johnson also work on a 4 cylinder two stroke merc? With the 2 cylinder it is attached to one plugwire and every pulse it counts is a revolution.With the 4 cylinder it is also attached to one plugwire and it still is one pulse per revolution.Is there some interference that makes is impossible to use the same tach? Or am I fine just using the same one?<br />Thanks for you answers.
