l008com
- Jun 14, 2007
- 751
My trailer has a relatively new connector plug (flat-4) and new lights. But the wiring itself connecting all these parts is as far as I know, original mid-80's copper. It includes a lot of basic plug connectors that go underwater all the time. I'm starting to have issues with that old copper corroding. And as always, I'm having issues with my grounds corroding.
So I'm coneplating just re-wiring the whole trailer. It's not that big a trailer so it's not that hard to do.
If I do this, I am DEFINITELY going to run a ground wire too. No more grounding to the frame, with self tapping screws that rust and corrode away.
One thing I've noticed that quality, durable flat-4 connectors don't seem to exist. Every harness I've seen has had small flimsy connectors with wires that feel like there's going to bend and snap off after a few uses. I trailer my boat so I connect and disconnect my trailer a lot, I'd love to find something a bit more durable than most.
But I guess most importantly of all, there's going ot be a lot of splicing going on here. What I've done in the past is use butt connectors and then heat shrink over that. But some of those connectors have had issues. What is the best way to make a super long lasting connection that is water proof and lasts forever? I'm going to have some three way connections if I'm going to make my own ground wire for this harness, i'm not sure how I can seal up a spliced connection like that. Any ideas? (do they make trailer harnesses with a ground wire? I haven't found any but that would be ideal)
