Re: Tire pressure: max pressure and actual pressure
The side to side rock or waddle is due to the fact the tire(s) probably have suffered a partial belt separation. That makes the belt run off true center so the tire waddles as it rolls over the uneven belt. Ever ride in a car with the same problem. You can feel the back end of the car waddle at 10 - 20 mph but it tends to lessen at higher speed. If you were to follow the trailer you would likely be able to see the separation as the tread waddles as the wheel rotates.
Silvertip, you hit it right on the money......... Hmmmm. It all makes sense now. So for example, say a guy lost a wheel going down the freeway at 70MPH on the way home from just buying a boat. Maybe a wheel and tire happened to fall off due to loose lug nuts. Luckily rolling past their truck going 70MPH, down the center median towards trafic then back in your lane, missing the semi tractor/trailer then rolling to a rest and being brought back to you in a M.D.O.T truck who happened to be behind you and seen the whole thing. I seen this all through my windshield. Tires will pass you up! ya, no fun.... There is a cut all around the very nice tread of the tire about 1/4" deep. Had a local tire shop mount it and balance it on a new rim. Even after i told them what happened, now i realize they should have known this tire could very well fail and it should be replaced. Least no one was hurt, and i found why i get that side to side wobble. The boat was fine minus a slight scratch where the fender was pushed into it. Had to replace the brake backing plate, brake pads, brake drum, lugs and a rim. Not too bad with all involved considered. I just thought it was a cheap knock off tire causing my wobble. Guess it's time to go tire shopping.
To dvan1901: here's a good example of what can happen to lack of maintenance on your tires/wheels/trailer. Don't get me wrong, i'm not saying your rig is unsafe or your not tending to it by any means. Just please address it. The last thing i would have ever thought was to check the tightness of the lug nuts when buying a boat.
