tire rating question
josh1981
Is it ok to have a stronger tire than is required? Meaning I only need a load range "C" tire (225/75/15) but can get a load range "D" for cheaper (I dont know why maybe supply and demand). Common sense tells me I will be fine and just have a stronger tire. I just wanted to ask and make sure that I am not overlooking something. Thanks
Re: tire rating question
Ayuh,... Heavier rated is just Fine,.... Under rated is Not...
j_martin
The D-range tire will have a higher inflation pressure spec on the sidewall, but odds are your rim won't be rated that high. Inflate to the c rating and you'll be fine. Just keep track of it so you don't over-inflate the tires and blow a rim. Not only does it wreck your day, it could take your head off.
hope it helps
john
josh1981
hope it helps
john
The d rating and the c rating both use a 15x6 rim. Is there a difference in rims? Will it be stamped on the rim anywhere? Thanks
H20Rat
rims actually have PSI ratings? Seems strange, rims are usually a fairly decent chunk of metal, and as far as pressure, there might be a 20 to 30 difference in psi. Not that much in the grand scheme of things...
Anyway, one thing to consider. On a typical rough riding leaf spring trailer, your tires provide some cushioning. Running higher capacity tires at their rated PSI is going to make for a rougher ride.
Mark_VTfisherman
Alloy and aluminum rims will probably be the only ones that show a load rating at a certain pressure. Steel rims have a max pounds rating. Steel rims won't show a max air PSI. Or I probably should say usually don't cuz someone somewhere will make one that does and someone will point that out :D
A "D" tire compared to a "C" tire has a 15# difference in max air pressure. If your rim doesn't have a margin or error or capacity ABOVE that little difference I would probably get new rims- ratings are generous enough to provide a margin of safety.
surge006
just a rougher ride on your truck
josh1981
Looks like i am going to go with a local dealer anyways instead of order the tires offline. So I will get the appropriete tire. Thanks for the input.
smokeonthewater
go with the heavier tires.... you don't have to inflate to max and they will handle better while towing
j_martin
Alloy and aluminum rims will probably be the only ones that show a load rating at a certain pressure. Steel rims won't. Or I probably should say usually don't cuz someone somewhere will have one that does and point that out :D
A "D" tire compared to a "C" tire has a 15# difference in max air pressure. If your rim doesn't have a margin or error or capacity ABOVE that little difference I would probably get new rims- ratings are usually generous enough to provide a margin of safety.
No they aren't. I've blown them. Don't do it. Inflate to the pressure the rim is designed for, and no more.
15 psi increase in pressure is a ton or more of increased sidewall force on the bead of the rim.
Mark_VTfisherman
...I've blown them. Don't do it. Inflate to the pressure the rim is designed for, and no more...
Steel rim, or aluminum?
Show us a published max psi chart for rims... Tires have PSI ratings, other than some Aluminum and alloy rims, rims are rated max pounds of load. I am all for learning but I am unfamiliar with rim ratings of max tire psi. We are not talking about overpressuring or overloading tires here- just whether he can use a "D" tire instead of a "C".
Most of the probs with Aluminum rims (or alloy) are with the old cast rims from the sixties, or the older welded-rim steel wheels meant for tube tires. Machined aluminum or alloy wheels have the load and PSI data provided by the manufacturer.
Running the D tires at the C pressure doesn't raise any alarms for me as long as the load capacity is not exceeded.
I do get your point though- I do remember tire training during which we were warned about welded steel and cast alloy wheels and newer tires or low-profile tires which had greater PSI. and something about old cast-and-machined magnesium wheels getting brittle over time- like Halibrand mags. But I haven't heard that brought up in recent years.
My 2 cents, but I am not a lawyer either.
JimS123
Look the tires over carefully to be sure they are USA made. I have personally had issues with every Chinese, Taiwan, etc. tire I ever bought. Even some of the USA name brands actually import some sizes. You can still find US tires, or at least you could as recently as 2 years ago.
smokeonthewater
I recently noticed that the alum rims on my dually state "do not exceed 65 psi"..... I have been towing with it at 80 psi for years and will continue to do so but it does make me nervous airing them up now and I am keeping an eye open for some different rims
Ayuh,... Ditto for me too..... Your claim sounds bogus...
red85k100rs
never seen a wheel blow, but seen the aftermath of an air compressor tank blow... you wouldn't want to be standing near it, or even in the same room!!
smokeonthewater
there is a chance that it would be fatal if you were right next to it. Like I said I am in the market for different rims
Frank Acampora
Well, His claim may sound bogus, but I learned a long time ago that unless I know facts to the contrary, not to reject a statement out of hand. I, for one, will file that rim pressure statement away in my mind for future invesigation.
