Ok, so I've read some threads/posts that talk of an engine being 'tired" whenever the boat is not performing as expected. Out of curiosity, can someone tell me what this means, and what to do about it? Thanks!
Tired engine as in the internals are worn out and require rebuilding. Usally low compression(less than 100psi) across all cylinders would tell you your engine internals are worn out.
