yes all gaskets were replaced when rebuilt, it is leaking a lot worse then the picture shows so much that its barely peeing. There is no water inside the lower cowling it is only coming from were the picture shows. Is the base gasket the only possibility, I would hate to pull the engine then wait for another gasket only to find out that was not the problem. Thanks in advance.
