Tnt is giving me the fits how much does a 98 225 ox66 hold in it's resivouir
Carmex12345
Ok what is the proper procedure to fluid completely fill the resivoier mind u i have my motor all the way down. So how mch does the fluid tank hold.keep in mind I've evacuated the entire tnt system by releasing the screw and dropping the motor sending whatever fluid out of the resivouir so I'm sure I need to refill the entire system tnt ve already put a half as 've already got the motor back up on the locks the support brackets.. I've been useing a 100 ml pediatric syringe and and I've gone through 3 quarters if a quart..what's the deal??any help would be greatly appreciated
boscoe99
Tilt the motor fully up. Remove the reservoir cap and add as much fluid as it will take. Install the cap. Trim the motor fully down. Then fully up. Remove the reservoir cap and add as much fluid as it will take. Install the cap. Trim the motor fully down.
Repeat as needed until no more fluid can be added.
