Re: TO FILL OR NOT TO FILL
I have a 150 Gallon tank as well. I talked to several marine mechanics. They all said stabilize where its at and run it. The amount of condensation in your tank should be minimal, and when you add a fresh 145 in the spring, you'll easily take care of any condensation in the tank. Just fill it all the way full in the spring, change your fuel water seporator. When you run through that 1st tank, you could change you separator agian if you'd feel better.
