Re: To foam or not to foam....
I put bottles in mine - just sealed it up this past weekend. A few tips i picked up on various sites and by doing it.
1.Open and screw closed the bottles on a cold day! That way, they won't be collapsing when it gets chilly out.
2. Have various sizes, mostly 2 liter. Fits in the tight spots.
3. Get some packaging foam to fill gaps on top to eliminate sliding around. NO WAY mine are moving, which was my biggest worry. They are in there tight. If the foam isn't sitting on the bottom it will not retain water.
4. Have a space a bottle won't quite fit?....open it, crush it into the spot base first, then seal it back up! This technique is how you jam them in tight.
I was very happy how my bottles worked out. They are more durable than you'd think and when fit in tightly they even provide a bit of floor stability! I assume they will also help in noise and vibration dampening, although I haven't been on the water with them yet.
Yacht Dr. soda bottles trap air and float, hense, the "pop bottle thingy", They also add a trapped air barrier for sound and vibration reduction (theory I read, anyhow). They have none of the negatives of poured in foam - water trapping. Now you can understand it, i hope.....still may not agree, but that's why many use this when replacing a floor.
My second choice would be to leave it empty.
