1983...It was designed to run on fuel of that era (Good fuel) and what we have today is crap compared to that. Your engine is a 90 deg crossflow and we've found in many, many cases and several years of testing, these engines run best when propped and set up for 5800 rpm. 5000 will load your ring lands with carbon, raise exhaust temps considerably higher than they were ever intended to run (again, due to the crap fuel we have today). That engine is 31 years old. it does not act the same on the fuel that we have today plain and simple, and yes, you will get many opinions but if you were able to ask anyone on this forum that knows my history they would tell you my tech advise is good and based on 40 years working and racing these Johnrudes. The hydrofoil is a "tool".....some tools are Band-Aid fixes for underlying issues. On a platform such as a bassboat, this is one of those issues. It comes down to what do you really want from this rig. You can run a 1000$ prop on this and still have the same problem. Are you willing to raise engine or possibly install a jackplate? Are you willing to test several props of different blade geometry to find the style that best fits your use desires? 3 vs 4bld?? $bld is always going to lift the stern more and will always have more wetted boat surface at high speed resulting in lower top speed. If you are willing to except speed loss, that's fine, but if youre willing to raise engine (4bld requires higher engine mounting height for best efficiency), you may gain some speed back but it will not be as good as the proper 3bld and correct set up. It really all comes down to the bottom line of what you want.
