Hello all. It's 2 degrees in Iowa, so possibly a strange time to think about boating... However my boat is in a heated garage and I'm starting to get optimistic that winter may in fact end at some point. Time to consider addressing an engine issue.
Boat is a 2005 with a 3.0 Mercruiser that I purchased last summer. In very good condition, always stored in a garage and appears to have very little use. Previous owner claims roughly 100 hours of use and I believe him do to next to no wear on the hull / vinyl / carpet.
The issue is this, the motor burns some oil. Roughly 1/2 quart per day on the water (4-5 hours of actual running, mostly at tubing speed). Runs smooth and has good power. Pulled the plugs, three have the nice tan color, one is a bit blacker. Not caked with carbon, but significantly darker than the others. Compression is good on all cylinders, I don't remember the numbers, but all are close to each other.
The question is this, could this be a result of the low use (possibly a stuck ring)?
It would be a financial stretch to have the engine pulled at this time, and I'm almost tempted to run it another year (50-75 hours) and then if things don't improve, put a long block into it. Is this a realistic plan?
Any thoughts or suggestions would be greatly appreciated.
-- Pete
-- Pete
