MassFourWinns94
- Oct 25, 2010
- 2
Hi
I have a 94 Four Winns Horizon 190 - 5.0L, with a Cobra/Volva SX drive - 3868076 - so I guess its a Volvo-Penta SX kind of drive with an OMC label. Well, the boat is new to me and I spent alot of time inspecting the engine (also a VP plate on an engine with an OMC sticker that my mechanic calls a "Ford"). Being new to boating, well, I don't know where the "Ford" bit came from.
I should have looked at the drive a bit more - but when I winterized it, the mechanic changed the gear oil and it was a milky-water mess. Mechanic suggested that I look for a used/rebuilt Volvo SX drive instead of him tearing it down and replacing the leaking gasket(s). He thought it would be about $1000 to do the teardown/fix of the existing drive. And he thought it would be about the same price for a used/remanufactured unit.
The boat's history is mixed salt and fresh water, most recently lakes. I took it out 3 times before season end and it seemed to run OK - reaches about 45 mph no problem. Only issue it would stall when cold and I put it into reverse. If I let the engine warm, then it wouldn't stall. We are replacing the bellows this winter since they had some cracks.
I see SX drives for sale (1994-through 1998) - rebuilt/remanufactured - they seem to run around $2000 (not $1000), then I tack on a few hundred more for installation.
Anyone have any experience with the rebuild/versus buy used/reman? Hindsight 20/20 moments? Given that $1000 is easier to swallow than $2000+ - I'm leaning on having him fix the existing unit.
