To Repower or not from mercruiser 470 to ???
ssn756
Here's what a have Mercruisere 470, yes I know all about the diverse opinions. should I fix what i have or look elsewhere :confused: This came out of a 73 2250 bayliner per the HIN. I think it might have been underpowered but I fix car not boats. Man are those some HUGE pistons. ahhhooooga.
I've already pulled the head off in hopes of spinining the engine manually but still frozen I'm thinking a main bearing.
the head was in actually good shape considering age, I believe this boat/engine was not properly stored which led to what I see. the bilge was 3/4 full of rain water and no telling how long.
Top portion frozen lower unit moves freely
Can I get by with replacing the studs or is it salvage?
ssn756
Re: To Repower or not????
The top is frozen don't know why will pull apart this weekend. and yes the transom is shot.
ssn756
Did I post in the right forum? Man I thought pictures would help a lot.:confused: :facepalm:
Hubboat
Did you try soaking the cylinders with Marvel, pull the oil pan?
The head doesn't look too bad, can't really see the cylinders tho. I am extremely optimistic when it comes to resurrecting things tho. That double cardian joint and outdrive teeth look rusty though. You could find a lower unit used somewhere tho if the engine ends up running.
This may be the forum for you
http://forums.iboats.com/forumdisplay.php?f=21
1979checkmate
belongs in i/o forum, not outboard
ssn756
I haven't.
After pulling the whole thing I've just been wondering if this thing is worth the trouble. I wonder if it's under powered/reliable. Figured id ask the guys with more experience than I do. I'm headed over there now. Thanks.
Here is a thread about that motor, interesting stuff, most says "run" though, lots of talk about over-heating. It's odd seeing an open deck design, alum. block and cast head too.
http://forums.iboats.com/showthread.php?t=374810
gonna check on that. I really would like to know the theory behind the design of this motor(fly on the wall). Thanks again.
JB
Crap.... I thought that's where I was at maybe one of the Mods will move me and not just lock it.
Here you go, ssn. Good luck. :)
Nope,... You've got Nothing to work with....
ssn756
I'm just getting that point to soak in, I junking the setup for scrap weight and looking for another boat. Oh well at least I didn't lose my lunch before I got decent advise.
ssn756
The cylinder head is the best part, I also think the block is good but I haven't removed oil pan yet. I'll try parting out for funds towards my next boating venture since this one didn't pan out so good.
I really appreciate the honesty and saving me from needless work. I think I made a good choice in registering here. :D
stonyloam
LOL glad you didn't junk the motor. if you go over to e-bay and search "mercruiser 470" you can get an idea of what stuff might be worth. Good luck with your next project.:D
