Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
For my Yamaha F150 it is basically a requirement according to the manual to use some type of support when trailering if you tilt the motor back. With my setup leaving the motor down, would result in the skeg hitting bumps in the road. I think this would apply to most situations, unless you have a trailer with significant ground clearance. If you have enough clearance, I'd say leaving the motor full down would be the best option. Check your owners manual to see what they say about trailering.
Trailer it up using a transom saver as it is too long to leave down (risk damage on bumpy roads) but if it wouldn't be a clearance issue, I'd tow it straight down.
