To trash or not to trash...
Nathaniel
As a new boat owner, I was wondering what I should expect from an older early 80's) Merc 7.5.<br /><br />I bought it used for about $400 earlier this spring. Since then, it has left me stranded on one occasion when the pump impeller went. Now the ignition module is gone, to the tune of $250.00. :( Am I just throwing good money after bad with this thing? I've had old cars that I kept on the road for decades without problems, can one do the same with outboard motors? I'm wondering if this is just bad luck or is the motor too old to use as an auxilliary motor for a sailboat. I've probably run it less than 30 hours.
sloopy
Re: To trash or not to trash...
WHAT!!!! A SAILOR WANTING TO TRASH AN OUTBOARD (if you do I will buy it) YOU PUT ME DOWN MAN, WAY DOWN, I WILL NEVER SAIL WITH &YOU!!! impellors fail all the time, you should of replaced it first thing when you got it, you have no idea how long it has bean there or what has happened, there great motors, just take care of it :)
steelespike
Many folks use motors much older than yours and you have to expect some problems with any outboard.If you havent changed the lower unit lube or dont know when it was last done do it now.If the dealer does it they will let you know if the lower unit needs any work.And you will save it from getting worse.<br />If you do it and the lube appears milky youll need to change the seals.
