Toggle Swith On Tilt & Trim
dk990496
Need to install a toggle switch on my tilt and trim there are 3 wires 1-blue , 1-red , 1-green does it matter were each wire is placed on the switch its for a 1983 115hp johnson<br />Thanks
roscoe
Re: Toggle Swith On Tilt & Trim
You need a 3 terminal toggle, preferably self centering.<br />Red wire- power- to the center terminal.<br />Blue wire, tilt up.<br />Green wire, tilt down.
dk990496
Thanks thought there may be a certain way it should hook up.Don't no if it works or not but at least i can try it.
rodbolt
hello<br /> always remember the sky is blue and blue is up. the grass is green and green is down<br />keep the smoke in and the rest is PFM :) :) <br />Good luck and keep posting
