Changed out the old water cooling impeller on my Tohatsu 8HP and pulling the lower unit off was easy, putting new impeller w/ keyway was done but now I can't seem to slide it all back together. Something seems to be hanging up and leaves assembly 1" short of fitting back in place and be bolted back together. Could it be the Gear change linkage? When I put pressure on the assembly to pull together, the lever is changing from Forward to reverse status. Can anybody shed light on what I am failing to do?
