Hi
I just purchased a second hand boat with a Tohatsu 90hp (2002 model). I've used it twice now and both times have been lucky to get a tow home as the motor refusses to start. On the first trip it started first go, We stoped and fished for 30 mins started no prob. Then pulled up on a beach and it refused to start come time to leave. As i said i got a tow and once back at the ramp kicked it over and it started no problems.
The second trip it started no problems - i suspected that maybe i had flooded it first trip, so out i went. Again come time to leave it wouldn't start, starter motor turned and alarm sounded but it wouldn't kick over (as if their was no spark). I disconnected fuel line and kept trying to start it - no go. Reconnected fuel line and re primed it - no go. I even sat there and let it sit for at least half an hour - still nothing. So second tow home and would you believe it, it started again back at the ramp. i have given it the once over and noted that the foward control was a little loose - maybe neutral wasn't engaged properly, but i did put it and out of neutral a few times. Have checked the spark plugs they are new, no sign of fouling. There is also no overhaeting of the engine. One thing is that the oil reservoir has been bypassed (the previous owner didn't want to replace the filter so he bypassed it). Oil is mixed in the fuel tank. That's all i have discovered so far.
So now i have a motor i don't trust and no money for a mechanic to look at it untill next monthly pay.
Any suggestions will be greatly appreciated
Dan.
Dan.
