Tohatsu Electric Start
Sea Rider
Is there a conversion kit to convert a tiller driven 2 stroke M50 D2 engine to be electric start ?
Happy Boating
Sea Rider
Thanks Paul,
Which parts does the kit includes ? A boater bought (5) 50 D2 to find out that are near impossible to rope start if with skinny arm, Was told, warned but ignorded the recommendation about buying electric start engines from the very beginning. A costly mistake indeed.
Happy Boatinmg
pvanv
3B7-76093-0*GROMMET, 25-51 3B7760930MGROMMET$2.01Low Stock
3C8-76010-1*STARTER MOTOR1 3C8760101MSTARTER MOTOR$456.12Low Stock
910103-5825*BOLT2OR 910103-68259101035825MBOLT$1.73Available
3C8-76007-0*RUBBER, STARTER MOTOR1 3C8760070MRUBBER, STARTER MOTOR$3.13Out of Stock
3C8-76009-0*BAND, STARTER MOTOR1 3C8760090MBAND$6.98Low Stock
910103-5820*BOLT1OR 910103-68209101035820MBOLT$1.35Available
346-76040-0*STARTER SOLENOID1 346760400MSTARTER SOLENOID$70.96Low Stock
910103-6616*BOLT1 9101036616MBOLT (10 MULTIPLE)$1.33Available
3C8-71035-0*BRACKET, STARTER SOLENOID1 3C8710350MPLATE$9.94Low Stock
910103-6614*BOLT2 9101036614MBOLT (10 MULTIPLE)$0.91Out of Stock
3C8-76141-0*STARTER CORD1L=1603C8761410MCABLE$13.16Low Stock
3B7-76120-0*BATTERY CABLE1L=30003B7761202MBATTERY CORD$129.20Out of Stock
910403-5612*BOLT1 9104035612MBOLT$0.00Out of Stock
3A3-76145-0*CAP, CORD2 3A3761450MCAP BATTERY CORD$3.13Low Stock
3B7-76145-0*CAP, CORD2 3B7761450MTERMINAL CAP, SOLENOID SWITCH$3.13Low Stock
3B7-76065-3*RECTIFIER1 3B7760655MRECTIFIER COMPLETE$112.30Low Stock
921503-7625*SCREW2 9215037625MSCREW (10 MULTIPLE)$1.02Available
3C8-76110-0*CORD ASSY "A"1 3C8761100MCORD ASSY A$72.98Low Stock
353-76062-1*FUSE WIRE1L=900353760621MLEAD WIRE ASSY$14.19Low Stock
3C8-76119-0*CORD ASSY "C"1L=5703C8761190MCABLE ASSY C$63.53Low Stock
3C8-76020-2*MAIN SWITCH1 3C8760202MMAIN SWITCH$66.89Low Stock
3C8-76080-0*NEUTRAL SWITCH1 3C8760801MNEUTRAL SWITCH ASSY$34.48Available
3B7-63731-0*WASHER, 12.5-24-11 3B7637310MWASHER 12.5-24-1$2.15Low Stock
309-06972-0*CLAMP, 6.5-47.5P1 309069720MCLAMP$1.91Low Stock
910103-0610*BOLT1OR 910113-06109101030610MBOLT (10 MULTIPLE)$0.86Available
353-06972-0*CLAMP, 7-80P2 353069720MCLAMP$2.01Low Stock
910403-0612*BOLT2 9104030612MSCREW (10 MULTIPLE)$1.37Available
Sea Rider
Paul,
Being M50 electric starter kit out of stock, will need to buy all what comes inside the kit separately, right ?
Happy Boating
gm280
Paul,
Happy Boating
Yes that would be my opinion. It seems your engine (and I have no ideas about it even a little bit) has the proper holes already for such an upgrade. So look for the main individual part numbers and search everywhere for them. One of those bidding sites would be a great place to look. The little stuff can be bought locally I'm sure. But this is only my opinion! :)
pvanv
Battery cord and a few fasteners are OOS; you can probably get those locally. Otherwise you would be OK to get the parts in the list.
Sea Rider
See a neutral switch on the list, if the engine will remain tiller driven, will still need the neutral switch ? assume this part is for remote control, right ?
Happy Boating
pvanv
The neutral safety is to prevent electric starting in gear, regardless of whether tiller or remote. If the motor were say at WOT, and started in gear, that could be quite a surprise, and very possibly an accident in the making.
Sea Rider
Paul,
Is kit code 3C8763002M same for M50D2 & M70D2 models ?
Happy Boating
gm280
I would be surprised if the engine didn't already have a neutrals safety switch already installed, or some other type mechanical lockout if not in neutral to start the engine. But I so easily could be wrong too!
Sea Rider
Yes, both engines have a safety mechanical lock in which can't pull rope if in other position than in neutral.
Happy Boating
Sea Rider
Paul,
40 & 50 are same CC, 70 has larger CC compared to. Is it possible to ask Tohatsu if same electric starter kit for the M50D2 matches a M70C. If so, could work to order both from you if that's ok with you.
Happy Boating
pvanv
They do use a common starter motor. but the part number for the bracket is different...
Sea Rider
I'm new to electric start engines, so it's a common starter motor for both, but each model must have its own propietary bracket, Does this part comes included in their respective model kit or needs to be bought separately if opting buying all needed spare parts to complet a kit ?
Happy Boating
pvanv
There is no kit for the US 70 hp models -- they are all electric start. So you would buy a 50 hp kit, and then get the 70 hp bracket... or get individual parts, but that would probably cost more.
Sea Rider
Paul,
There's no such M70 D2 model, just stayed at M70C just like the old M40C. Ok about data, thanks
Happy Boating
