tohatsu lower unit question
livdogred
I have just replaced my 40D tohatsu cooling kit with success but my only problem is, is it necessary to put some gasket sealer between the gear lower unit and the leg, because when i have removed the lower unit there was no gasket.10x.:)
pvanv
Re: tohatsu lower unit question
The water pump kit should include:
Impeller
Impeller key
Pump case liner
Guide plate
Guide plate gasket
Pump case gasket
4 bolts
There is no gasket between the LU and the driveshaft housing, if that's your question.
livdogred
Yes that was my question 10x very much for your help.
