ronaldhase
- Mar 2, 2021
- 4
can anyone tell me how exactly to install the water pipe upper seal and collar and locking rubber seal on the water pipe? i can see the exploded view on the order and direction they go on but not how far up the pipe to install before installing the lower unit that has a rubber seal attached to the top of the water pump.. no matter how i install with or without the upper seal and collar and locking rubber seal i still get water pouring out of top of middle case just behind motor mounts to boat.. is this normal for "excess water" the motor cant take? i bought this boat used and not running. when i first removed lower unit there was no upper seals or collar or anything on the pipe. the rubber that locks onto top of water pump was all that was there so i am attempting to add the water pipe components in an effort to correct. any info would be much appreciated..
