Hello,
I'm new to the forum and new to outboards. I got this motor for 400 dollars and its super clean. Starts first pull and idles great. I changed the lower gear oil and entire fuel system(lines, filters, etc...) I even cleaned the entire carb inside and out and replaced the diaphragm. However when under load its struggling to get up to speed. It seems like it's not getting enough fuel. When I manually open it to WOT it will get up and go. Pumping the primer bulb has no effect on engine performance. I always check to see if the vent is open on the tank. I think I'm getting air in the line somewhere. can anybody help me? Is there anything else I should take a look at? Any help is appreciated!
