Tohatsu MFS6 squealing noise
Leiv
I've got one of the Tohatsu 6hp 4-strokes, a 2014 model I think. Bought new in 2015. There have been many small issue with it, to be honest, but I on the whole it has kept working. Very worrying is an intermittent noise. Sometimes it's the faintest of squeaks, other times a very loud metal-on-metal kind of squeal, always in time with the piston strokes. Hard to tell where the sound is coming from exactly. When it's at its loudest, there is a small drop in engine rpms as well. Sometimes it persists for minutes, other times it will stop suddenly. Often, stopping and immediately restarting the engine will stop the sound.
I'm thinking it can only be a lack of lubrication (I have checked and changed oil) if it's in the powerhead, or a failing bearing if it's lower down. I'm a long way from a dealer or workshop, so I'll have to do the work myself, but would appreciate any ideas that could save time and money (knowing what gaskets or parts to order in advance, for example).
pvanv
The MFS 4/5/6 has pressurized lubrication, so oiling is seldom an issue. More common is something rubbing in the recoil apparatus. Verify that the LU lube is topped all the way up; if it's low, the bearing just below the water pump could starve for oil.
Sea Rider
Remove the whole recoil assy, start motor with rope and check. If issue doesn't show up, it's a recoil issue. Clean, lubricate, adjust whichever needs to be done and boat happily forever.
Happy Boating
Leiv
Thanks for the suggestions. I will take a look in the recoil assembly before trying anything more invasive.
Leiv
I removed the recoil and the flywheel. Still getting the squeak when turning the crankshaft with a wrench. It's definitely coming from inside the powerhead. Will let you know what it was if I ever find out.
pvanv
Did you verify LU lube level? If this is an UL, did you check the bushing inside the exhaust housing?
Sea Rider
If oil level and bushing are OK, could be a upper crankshaft bearing turning bad. Will ned a sthetoscope to troubleshoot and find from where is the squealing noise coming from as not to wild guess.
Happy Boating
