Sorry if this is a newby question but I'm having a few issues finding the routing for some wiring and hoses. I just picked up a new to me 2011 75 TLDI and I wasn't there to see everything some apart. If someone would help me with the routing of the fuel line from the filter (forward under the oil tank and out the front of the cowl?), the location to connect the battery cables (negative I assume is anywhere to the block? The supplied battery cable positive has such a small terminal on it I can't believe it came from the starter post. The last issue doesn't involve wiring, the oil tank is lose. Can anyone enlighten me as to how in the world you reach the two bottom bolts that secure the oil tank. I think the bolts are there but the rubber washers are shot and the tank flops all over the place. Hopefully these are the only issues I need to resolve to get on the water. I managed to find some missing clips and washers laying in the cowl for linkage and routed the trim sender where I think it makes sense. Things just weren't taken apart and marked like I would have hoped. Any assistance would be greatly appreciated!
