Tohatsu
rbronston
Hello I have a tohatsu 15 hp . After about 10 minutes of running it bogged down. Then I have to pump the bulb again. It will run the bog down again. This continuous. Any idea what the problem could be. I got a new hose and it is still doing it. Thanks
redneck joe
Sounds like the tank is not venting. Try running with the cap off. Im assuming it is a portable tank and you have already ensured the vent screw on the cap, if it has one, is open.
Jeff J
The bulb would be collapsed if the tank isn’t venting so he would not be able to pump it up.
I would think filter or pump.
