jitterbug127
- Feb 6, 2023
- 637
1990 15 hp long shaft motor. It was previously running 17 mph wide open throttle pushing my Jon boat. I ran some questionable gas through it, and I was needing to completely rebuild carb so I went ahead and did that. Also new fuel lines, new fuel pump, new cam roller, impeller, gear lube etc. I using the same bulb and tank I was when motor was running good, so I know problem isn’t with that. Actually tied second bulb/hose just to see and had same results. Motor will now run strong and throw water out of the bucket, but it will not do much of anything on water. I’ve got spark in both cylinders and 100/105 compression.
Slow river video is today, fast river video week or so ago
