Tools to Cut Fiberglass
dependablejoe
What tools do people like to use to cut CSM & 1708?
I tried using my regular scissors, but after a couple of small cuts I have to sharpen them.
I was thinking of trying either "Wiss W20 10-3/8-Inch Inlaid Heavy Duty Industrial Shears"
or
"Fiskars 199600-1001RazorEdge Fabric Shears/Seam Ripper for Tabletop Cutting , 9 Inch"
Thoughts?
steve_h7
I bought a pair of Fiskers and they lasted throughout the whole build.
I started tearing the CSM as opposed to cutting it because it results in a very nice edge that needs very little sanding when planning to put a final coating of gelcoat over it. Just fwiw...
froggy1150
Master Chief Petty Officer
So I have a pair of fishers "eversharp" (I think that's right) those I only use on dry clean glass and still perfect, I have a second set of fiskers that are a bit cheaper that I use for wet cuts. These I have to sharpen time to time. For csm only I also use a small olfa knife. (With the snap off tips ) I drag this across the too of csm and score the glass then I tear it. Don't take much pressure either. You want the ends frayed. It will help with wrapping corners and blended overlaps
I have a set of fiskars that I have used for years, I also have a set of tin shears that I also use
NatedoggAZ
I used a pair of scissors and a razor blade knife I got at the dollar store... never had an issue
dezmond
I love using my Fiskars rotary cutters. Super sharp and clean cuts. I cut on a cutting mat, aluminum, concrete. Didn’t matter. Yes the blade will fill quick on the hard surfaces. It using a mat it will last a long time.
kcassells
I like using lobster claws.
Those guys are correct. Get 2 pair cause 1 will get gluey. :joyous:
th
oldrem
I use a Pink Power cordless electric shears to cut fiberglass, vinyl and carpet. Hasn't failed me yet
Woodonglass
Razor knife!! Glassing does NOT require or desire a CLEAN CUT edge Fuzzy edges are actually the best. Just get it close and then tug and pull the edges to loosen the fibers, Makes everything blend together really well.
