Hey guys its been a while since my last post put I got another head scratcher this time. I have a 1973 3cyl johnson 65hp. that I rebuilt 2 years ago that had been running great up until the end of last season. Seens to be running lean on top cyl. Good compression and spark on all cyl.I have cleaned and rebulit carbs and installed mew fuel lines and bulb. Question is, this model fuel inlet is in the center carb and then distributes to top and bottem carbs. If top carb is running lean what else is there to check or replace? Fuel does get to the top carb with pumping bulb but seem to quit when running above half throttle. <br />thanks for any help.<br />Bobby
