TOP SPEED CALCULATIONS for VP-270HP SX
MEADVIEW
Is there a way to calculate what the anticipated Top Speed of what a boat should be? Last month I ordered a 2004 FourWinns 194 Funship with the VP- 270HP-SX @ 3600 lbs dry weight. The specs say it tops out @ 37.1 MPH, for that eng. & drive pkg,( hope this was typo).I have also reviewed several heaver boats with the same drive and Eng. pkg that are showing much better top end speeds 45-49MPH. Does any one out there have a similar boat & drive pkg that could give s better idea of what might be expected? <br /><br />Thanks / Meadview
JB
Re: TOP SPEED CALCULATIONS for VP-270HP SX
Maybe the formula for estimating WOT for an ideally rigged and propped outboard boat would help, Meadview.<br /><br />MPH=(square root of HP/weight)X 200<br /><br />For your boat, 270HP/4000lb = .0675,<br />square root = .2598<br />times 200 = 51.96MPH<br /><br />The 4000lb is my estimate of "on the water, fueled and loaded".<br /><br />The 200 is a "bottom factor", If fits your boat. If your boat is deep vee, it should be reduced to 175, in which case the MPH would come out as 45.47MPH.<br /><br />Good luck. :)
Doug Durako
Calculations are interesting---on-water tests are the only way to tell. Talk to someone who owns last year's model and/or go to the boating magazines and find one that's tested your model.<br /><br />Deck boats are slower by design.<br /><br />Did you drive a boat like this before you ordered one?
JB
Hull factor for a deckboat should be 150. You didn't specify a deckboat.<br /><br />Calculations to estimate are just that: estimates.<br /><br />For your deckboat the calculated estimate is 38.97, IFF it weighs 4,000lb on the water and IFF it is ideally rigged, propped and trimmed.
MEADVIEW
JB,<br /><br />Thanks for the info......... (Good Stuff)<br /><br />DDBoater,<br />I did not get a chance to drive one before buying (no one had one available) Top Speed was not a big concern, just thought the numbers seemed kinda low for the power plant. I purchased off the reputation of Four Winns.
Wingnutt
That formula is pretty close. My Regal probably weighs close to 2800lbs fully loaded and with my fat 'ol butt in it, and has a 190hp 4.3 in it. The formule says 44mph and I can get 41-42 out of it on glass smooth water. :)
"out of it on glass smooth water." <br /><br />That's Where the other 3 or 4 mph are.......<br />Boats are Always Fastest on a 4"to 6" Chop.......<br />Gotta be able to Air it Out abit.......
bvh
I have the same boat with a 220ho 5.0 and an sx drive. With a light load and a SS 19 prop, I get 48-49mph at 4800rpm. Here is a spec sheet from Four Winns about the 194. It shows the perfromance of most of the drive packages available for that boat. I think it has a typo on the SX prop pitch, as they are all listed as 21's, but mine was delivered with a 19 as was the one I test drove. <br /><br />194 FUNSHIP<br /><br />Specifications US METRIC<br />LOA: 21’3” 6.40 m<br />Storage Length: 21’11 6.68 m<br />Beam: 8'6" 2.59 m<br />Keel to W/S Shelf: 4’9” 1.45 m<br />Total Height: 5'11" 1.80 m<br />Total Height on Trailer: 7'4" 2.24 m<br />Transom Angle: 13˚ 13˚<br />Deadrise: 17˚ 17˚<br />Bridge Clearance: 4'9" 1.45 m<br />Cockpit Height (stern): 29" 74 cm<br />Cockpit Height (helm): 35" 89 cm<br />Freeboard (min.): 32" 81 cm<br />Draft (drive down): 31" 79 cm<br />Draft (drive up): 14" 36 cm<br />Fuel: 50 gal. 189 l<br />Persons Capacity: 11 11<br />Maximum Capacity: 1700 lbs 771 kg <br /><br />Power Ratings & Weights <br />Engine Propshaft Power Boat & Engine Weights<br />Type HP KW Lbs KG<br /><br />MC4.3L/A 190 142 3700 1680<br />VP 4.3GL/SX 190 142 3750 1700<br />MC4.3MPI/A 220 164 3730 1690<br />VP 4.3GXi/SX 225 169 3780 1710<br />VP 4.3GXi/DP 225 169 3800 1720<br />MC5.0L/A 220 164 3800 1720<br />VP 5.0GL/SX 220 164 3850 1750<br />MC5.0MPI/A 260 194 3810 1730<br />MC5.0MPI/B1 260 194 3900 1770<br />VP5.0GXi/SX 270 201 3860 1750<br />VP5.0GXi/DP 270 201 3880 1760<br /><br />Recommended Engine(s)/Equipment Avg. Weights<br />Model Eng. Type Boat Eng. Battery Fuel Access. Trailer Wt. <br />LBS<br />194FS VP 5.0GL/SX 2790 1000 60 300 150 1160<br />KG<br />194FS VP 5.0GL/SX 1265 454 27 136 68 526<br /><br />Performance<br />Power HP/ KW Propeller (Dia x Pitch) Type Top Speed Cruise Range<br /> IN CM MPH KPH MI KM<br />MC4.3L/A/190/142 141/4 x 21 36 x 53 AL 44-47 71-76 160 258<br />VP4.3GL/SX/190/142 141/4 x 21 36 x 53 AL 43-46 69-74 160 258<br />MC4.3MPI/A220/164 141/4 x 21 36 x 53 AL 46-49 74-79 160 258<br />VP4.3GXi/SX/225/169 141/4 x 21 36 x 53 AL 46-49 74-79 160 258<br />VP4.3GXi/DP/225/169 F7 F7 SST 47-50 76-81 170 273<br />MC5.0L/A/220/164 141/4 x 21 36 x 53 AL 46-49 69-79 150 242<br />VP5.0GL/SX/220/164 141/4 x 21 36 x 53 AL 45-48 72-77 150 242<br />VP5.0GL/DP/220/164 F6 F6 SST 46-49 69-79 160 273<br />MC5.0MPI/A/260/194 141/4 x 21 36 x 53 AL 48-51 77-82 160 273<br />MC5.0MPI/B1/260/194 143/4 x 21 38 x 53 SST 48-51 77-82 160 258<br />VP5.0GXi/SX/270/201 141/4 x 21 36 x 53 AL 47-50 76-81 160 258<br />VP5.0GXi/DP/270/201 F6 F6 SST 48-51 77-82 170 273<br /><br />Fuel Flow Data - 194 FUNSHIP with VP4.3GL/SX/190/142& MC4.3L/A/190/142<br />Engine Speed - RPM Boat Speed Fuel Flow<br />MPH KPH GPH LPH<br />2000 8 13 4 15<br />2500 12 19 5 19<br />3000 26 42 7 26<br />3500 32 52 10 38<br />4000 39 63 13 49<br />4500 44 71 16 60<br />WOT 46 74 18 68<br /><br />Fuel Flow Data - 194 FUNSHIP with VP4.3GXi/SX/225/169& MC4.3MPI/A/220/164<br />Engine Speed - RPM Boat Speed Fuel Flow<br />MPH KPH GPH LPH<br />2000 8 13 4 15<br />2500 12 19 5 19<br />3000 26 42 7 26<br />3500 33 53 10 38<br />4000 40 64 13 49<br />4500 45 72 17 64<br />WOT 48 77 19 72<br /><br />Fuel Flow Data - 194 Funship with VP4.3GXi/DP/225/169<br />Engine Speed - RPM Boat Speed Fuel Flow<br /> MPH KPH GPH LPH<br />2000 8 13 4 15<br />2500 18 29 5 19<br />3000 27 43 7 26<br />3500 35 56 11 42<br />4000 42 68 14 53<br />4500 46 74 17 64<br />WOT 49 77 19 72<br /><br />Fuel Flow Data - 194 FUNSHIP with VP5.0GL/SX/220/164& MC5.0L/A/220/164<br />Engine Speed - RPM Boat Speed Fuel Flow<br />MPH KPH GPH LPH<br />2000 8 13 5 19<br />2500 13 21 6 23<br />3000 27 43 8 30<br />3500 34 55 12 45<br />4000 42 68 15 57<br />4500 46 74 17 64<br />WOT 47 76 19 72<br /><br />Fuel Flow Data - 194 Funship with VP5.0GXi/SX/270/201 & MC5.0MPI/A/B1260/194<br />Engine Speed - RPM Boat Speed Fuel Flow<br /> MPH KPH GPH LPH<br />2000 9 14 5 19<br />2500 18 29 7 26<br />3000 28 45 9 34<br />3500 36 58 12 45<br />4000 43 69 15 57<br />4500 48 77 19 72<br />WOT 50 81 21 79<br /><br />Fuel Flow Data - 194 Funship with VP5.0GXi/DP/270/201<br />Engine Speed - RPM Boat Speed Fuel Flow<br /> MPH KPH GPH LPH<br />2000 9 14 5 19<br />2500 19 31 7 26<br />3000 29 47 9 34<br />3500 38 61 12 45<br />4000 44 71 15 57<br />4500 48 77 19 72<br />WOT 50 81 21 79
Doug Durako
Mead---don't get me wrong---Four Winns is a fine vessel. Once you get to the horsepower rating you are looking at, the extra speed comes from hull design. I am running the standard 250 hp small block and I get 62.3 mph (GPS) with just me and fuel and ideal conditions.<br /><br />Your concern will be hole shot on that deck boat design, especially if you are going to run with several people in the boat and try to pull skiiers, tubers, etc.<br /><br />With my fixed blade, 21 pitch, original equipment Mercury SS prop, my kids (in their 20s, adults by age calculation) and their friends had some trouble pulling tubes (8 in the boat, two or three on tubes).<br /><br />The Torque-Shift prop took care of the hole shot (you really do have to sit down when you hit it, no matter how many are in the boat or they will fall out), but I lost 2 mph on the top end.<br /><br />Still tweaking.
MEADVIEW
BVH,<br />You are the only other person I know of that has one... Your engine is the 220HP, and you are running 48-49 w/light load. Are you are pleased with the performance?, Any thing I should look for when accepting it from the dealer?<br /><br />I guess I'll wait and see what the performance "actually" is before I bug you guys with any more questions.. (I should have it in the water by next week if the delivery sked holds)<br /><br />Thanks Again,<br /><br />Meadview
