Lake Skywalker
- Aug 23, 2011
- 3
Hi all; Huge problem regarding my 120 Force,I bought this boat and it started right up on the muffs,so far so good,took it out to the lake and when I was at full throttle it was only making like 10 mph.Got it back home,fired it up on the muffs and did a spark plug drop test.That`s when I discovered it was only firing on the bottom two cylinders.I did a compression test and all holes are between 120 and 125 p.s.i. which is not too bad.Did a leak down test they were all good.Put it on a spark tester and they all had great spark.Put a Boroscope in the spark plug holes,pistons, etc. look good.Re-did the top carb,both carbs are getting fuel,but when I put my hand over the top carb intake,it`s barely drawing any air in,I also pulled out the reed plates they are also nice and tight and all there.My buddy who is a marine Mechanic said he`s never seen this issue in 15 yrs of working on boats.I`m stumped,he`s stumped,anyone have any suggestions? Thanks!!
