SS MAYFLOAT
- May 17, 2001
- 6,372
I'm kicking around ideas of remodeling my basement to appear as if in a mine shaft or a cave.<br /><br />My one exterior basement wall (block) is 44 feet long. Can I use plastering screen anchored to the wall to form like stones and bolders? What should I use to cover the screen, Plaster or Cement? After everything is shapped and moulded, I'm planning to airbrush details onto the surface to enhance a stone look.<br /><br />Problem with the wall is it leaks water only when my down spout get clogged. The gutter was 65' with only 1 downspout, but I added one at the other end of the house. Of course I changed the drop on the gutter to a 50/50 drop to both downspouts. Since then with heavy rains I haven't had any more problems with the water leaking in.<br /><br />If it happens in the futher, I don't want the water messing up my future project with this wall. It currently has paneling on it and of course it is runined. Buckled, warped, and just down right ugly.<br /><br />I had this planned way before SBN started with the Cave thing. Dang on him....
<br /><br />Any tip would be helpful. I have done some masonary projects, but not as extensive as this. <br /><br />Seen your pics on the other post, and I must say you are professional grade. Its takes talent to do such great work... Thats why I'm asking you for the tips. Thanks....SS
