ECM has nothing to do with where the engine makes it's power.Don't know why Volvo wouldn't publish that info. I would like to see where the engine makes the most torque and hp. If the engine make the most in the upper rpm range I would like to see if the ecm can be reprogramed to get the most in the 2500-3500 rpm range.
The ECM has lots to do where the engine makes its power. It controls the air/fuel mixture, timing and other variables. Why do you think they sell programmers for cars and trucks. Super chips, bully dog are a few companies. They reprogram the ECM.
You might be able to slightly increase power across the curve but you aren't changing the shape of the curve one bit. You aren't going to move the peak torque to a lower RPM if that is what you have in mind.The ECM has lots to do where the engine makes its power. It controls the air/fuel mixture, timing and other variables. Why do you think they sell programmers for cars and trucks. Super chips, bully dog are a few companies. They reprogram the ECM.
