tourqe specs
Hotrods
Re: tourqe specs
For what part? If you are rebuilding, you really need a manual...Really
Hotrods
Re: tourqe specs
Oh,, it probably for your heads right. Off the top of my head im thinking 18-20 ft lbs
fireman_103
Re: tourqe specs
Yes just the heads, I have been told that there is a certian order that need to be followed in the nut pattern
Hotrods
Re: tourqe specs
yea there is, if you have the 10 bolt head which I think you do.. Im looking at it but its hard to explain... hummm. lets see if this works. yea there you go. in this order starting with 1<br /><br /><br />7 8<br /><br />3 4<br /><br /> 2 1<br /><br />6 5<br /><br />10 9<br /><br /><br />Dont take them to full torq in one shot, make it 3 times.. alittle at atime
fireman_103
Re: tourqe specs
So what it looks like is that i go 1, 6, 5, 10, 9, 7, 8, 3, 4, 2, With 7 being on the top left?????
DHPMARINE
Re: tourqe specs
start with the middle two bolts,one port,one starboard.Then do the two bolts above that,first starboard then port.Then do the two bolts below these,first port then starboard.When you are out of bolts,you are done.OMC uses a criss cross pattern that works also.I find this circular pattern works well on heads.<br />DHP
fireman_103
Re: tourqe specs
Got them on today. Got one bolt that seems to be stripped, got to take it out later and check it. I didnt do a compression check yet but I did put her in the water for a while and ran around a little. Still got to do the carbs. Hopefully the patching i did on the heads ( block )seal ring of all places will hold up.
