i_build
- Apr 24, 2005
- 144
Out of nowhere while up on a plane she slows down a little and drops out of gear. I tried to put her in forward or reverse and it's as if she is in neutral. Tilt the out drive up and put it in gear with engine off and the prop locks. Just changed the shift cable and that seems fine. Also changed pump and I noticed she heated up to 200* just before I shut her off. It's almost as if the shaft isn't turning. Could it be a broken ujoint? Or is my drive hosed? Or anything else. She cruised out to the fishing spot no problem and went in and out of reverse no problem and I had been driving a good 10 minutes without any increase in temp just till she lost engagement somewhere.
