kungpaoshizi
- Apr 29, 2013
- 221
So it shimmies slightly (twisting kinda) every now and again. It also seems to start at the ramp without a problem. Then after running around all over, idling, running around, etc, then I shut it off. I can let it sit 15 minutes, try to start it and it seems to crank over and start at a low rpm, maybe 700ish and then kinda drops, drops, dies.
The above happens even if I have the high idle lever up all the way.
It will act like that for a few starts, and then it all of a sudden sees the high idle is up and will tiredly go back to normal. I let it warm up a little bit, and it's like nothing happened, until the next time I let it sit for a period of time.
This is my first boat, and I still think it was a hell of a deal, but man evidently boats are harder to troubleshoot than cars.. and I'm not an expert in that area either!
I plan to change the internal wiring harness (some cracked wires, slight corrosion here and there) and have the fuel pump rebuilt (or should I go new for new aftermarkets?) and double check idle mixture. This is going to be over the next week but I was wondering what peoples thoughts are. I really like the performance but have a feeling the PO didn't take as good of care of it as they think they did... I mentioned reeds to the guy and he said it's too tough of a job, they're made of metal and pretty much last forever?
Thanks very much for any input!
1986 Venture Stallion Bass Boat w/1977 1150 Tower of Power
