Towing a Sylvan V178 with GLK350
Rturn19
Anyone know the weight of a Sylvan V178 Barritz? I read it is 1565 dry, so I estimate around 2500 LBS with trailer and fuel. My car (2010 GLK350) is rated at 3500lbs towing capacity. Should I be ok towing the boat?
badrano
What's the gross wieght rating of the trailer? Take the gross wieght and subtract the wieght of the boat. With the remainder, take a little bit more off and the final number could give you an idea of the trailer wieght. This is a little bit of fuzzy math as the wieght of the boat and trailer should be some amount less than the trailers gross wieght rating.
What are the gross wieght and gross combinational wieght ratings for your car. When you add up the wieght of your car with passangers and gear along with the wieght of boat, trailer and additional gear in the boat, the total value can't exceed the gross combinational wieght. The 3500# rating basically assumes the car and the driver and no additional passangers or gear.
I tow 5000lbs and my vehicle is rated for 6200 lbs. I can't tow a full 6200# with my family in the car because I will exceed the gross combinational wieght. For me, I really should get a bigger tow vehicle but since I'm not in the hills, it's not a big issue at this point since I only tow to the shore which is 1-2 hours away. It will become an issue if I want to tow in to the hills.
