Towing boat and trailer with front drive Car
Status
Not open for further replies.
plztellme
Newbie here. I own a 16ft bow rider and trailer. My tow vehicle is a 2009 front wheel drive Impala and will be towing my boat about 10 miles one way. I travel mostly secondary road, but once in awhile a major highway. Should I install a tranny cooler and will I have any problems at the launch?
Home Cookin'
Re: Towing boat and trailer with front drive Car
i wouldn't worry about anything in those circumstances.
plztellme
Towing boat and trailer with front drive car
Newbie here. I own a 16 ft. bow rider with trailer. My tow vehicle is a 2010 front wheel drive Chevy Impala with a 3.2L engine. I will be towing the boat about 10 miles to the lake. Most times I travel secondary roads, however, once in awhile I will take the highway. Should I install a tranny cooler and will I have any problems with pullng the boat out of the water?
oldjeep
Re: Towing boat and trailer with front drive car
How much is the car rated to tow and how much are you towing?
tpenfield
Let the owner's manual of the car be your guide as to the towing abilities.
plztellme
Don't know what the car is rated at for towing, but the tongue weight is about 1,000lbs. with the boat and trailer.
tomdinwv
What's the towing capacity on the Impala and how much does your boat/trailer weigh?
scoutabout
That can't be right. You mean the entire weight of the boat, gear, and trailer is 1000? Tongue weight is the actual weight resting on the rear of your tow vehicle - i.e. couple of hundred pounds at most for the size of boat you are describing.
I'm also guessing that your guess about total weight is a little off. Even the trailer for a boat that size is going to weigh 400-500 pounds. So, all up you are probably pushing 2000 or more unless we are talking a stripped tinnie. You also need to take into account gas and gear. That will add a few hundred pounds easily.
As an example, the boat you see in my signature (17 foot dual console i.e. bowrider outboard) totals up as follows: bare hull - 1100, 90 4 stroke engine - 400, trailer - 500, gas and gear - probably 300. Total to tow = approx 2300 pounds.
Anyway, as others have said - let your owner's manual be your guide. Can't hurt to have the whole shebang weighed at a truck weigh station so you know for sure.
FWIW - I have towed with front wheel drive vehicles and as long as you don't get stupid with the load or driving, they have been fine in my experience. Where you might run afoul is at the ramp, where you have a ton of weight pushing the rear of the car down, thereby impairing your traction on the front end. I'd stay away from all but the most gentle of slopes.
maproy99
He said it was only 10 miles on back roads and everyone is already freaking out about towing too much. The only issue I see is with a steep ramp. But if you invest in a rolling tongue jack for the trailer, just lower it down to remove the weight from the hitch while keeping the ball connected and much less of a traction issue trying to pull the boat out, just a slight inconvenience.
Heck, you could probably even lift your rear axle up off the ground that way if you needed to.
ricohman
Tongue weight of 1000lbs?
I have that on my F350 when I'm towing my flat deck with another truck, tools, welder ect. But that trailer is more then 10 000lbs.
Is your boat/trailer that big?
If it is, there is no way you can pull that with the Impala.
plztellme
I found out that the car is rated for towing of 1,000lbs. Boat w/gas, trailer and motor probably will weigh somewhere around 2,000lbs give a little.
plztellme
No, I typed in the wrong info. The car is rated to tow 1,000 lbs, so I'm guessing the tongue weight is about 2-300lbs. Boat, trailer, motor and about 15 gal of gas in the boat will probabably weigh about 2,400 lbs. If that's the case, will I have any of the stated problems towing or pulling the boat out of the water on a gentle slopped ramp?
tx1961whaler
Yes. Problems. You are trying to tow more than twice what the car is rated for. Please don't consider it.
helimech2003
Can you do it? Sure.
Should you do it? NO.
The transmissions in these cars are marginal at best. If you do pull with it plan on a new transmission at least once a year even with a tranny cooler.
Dont ask me how i know
Pony
I don't think anyone was freaking out.......
BTW a lot can happen in 10 miles. Every single accident I have EVER been in has happened within 10 miles of my front door.
He also stated that he would be on "mostly" side roads....BUT WOULD TAKE THE HIGHWAY AT TIMES.
The only issue you see is the steep ramp?? :eek:
Mikeyboy
You are asking for serious trouble trying to pull that boat with that car. Can you tow with a front wheel drive car? Sure. But that is way to much wieght. Not only are you probably going to destroy your car but should you have an accident wether its your fault or not you can be held criminally liable for exceeding your legal tow limits, especially more than doubling it. It is a really bad idea and way more than your car is on the line. I really hope you do not do it.
Oshkosh1
Ensign
It's not necessarily the TOWING(as in the process of pulling) which could be a real issue, but the control, and BRAKING aspects.
Can you tow it? sure...
Can you control it and stop it in a reasonable and safe manner in an emergency? Probably not.
jkust
I'm going to say at 2000lbs, you will invite more trouble than you may want. I forsee several possible difficulties the least of which is actually moving that much weight.
ezmobee
I towed a lighter boat with pretty much the same car ('00 Buick Regal) and it did not do real well. It was particularly miserable on the ramp because I couldn't back the boat in as far as I would have liked for ease of launching and retrieving.
Status
