Towing over rough terrain with outboard down?
matt167
I’m going to move my boat to my girlfriends. Which has a 1/4 mile un paved driveway. I tow with the motor down and about 8” of ground clearance to the skeg. It tows perfectly like that. Think it’s safe to bring that over a bumpy driveway with a steep entrance where it drops in? I tow with the battery out as well so I don’t really want to pull off the side of the road to raise the motor
go slow, enter the drive from an angle
Grub54891
Leave the battery in and raise the motor when you get to the driveway. Simple.
matt167
The battery jumps around going down the road and there is no place for a hold down under the splash well But I might just have to do it on the side of the road
Grub54891
Battery has to be strapped down per Abyc regulation. Regardless, I know in a small boat it’s not easy to do. How about one of those small hand held jump packs to trim up? Or a transom saver to keep it up a bit higher. Or trim up completely, and swing the trim lock down and just go….
matt167
I don’t like it either but a marine battery box does not have clearance where it is. The only thing I could do is put in a universal hotrod type battery hold down screwed to the floor. But it’s a 66 so i don’t know as all the regs were in place then
roscoe
Doesn't matter what the law was in '66.
The law says all batteries must be secured, and terminals covered.
There's a reason.
garbageguy
8" skeg clearance? Do you have more than 8" clearance in the rest of your rig, and are towing in a forward direction?
matt167
There's a reason.
It also says that a boat of this size needs floatation even though I don’t think it ever had it. I think stuff does get grandfathered just like cars safety systems. This doesn’t mean I’m not looking for a solution but I haven’t found what I need yet
poconojoe
Why would you trailer with the outboard down?
Why take the chance?
You might hit a speed bump or drive up an incline and make contact.
If you're paranoid about the engine bouncing, get one one of those transom saver bars.
matt167
Motor down is less stress on the transom and under normal circumstances the trailer has the clearance
poconojoe
Transom saver.
A simple adjustable bar that supports the outboard by spanning between the engine and trailer frame.
JimS123
NEVER trailer with the outboard down. Use a transom saver or secure the engine with a twobyfore and bungees if you don't want to spend money.
MY FIL and I had this argument for many years. His last 5 miles to his camp was a rough dirt / stone road. His last trip with the motor tilted up was a disaster. He called me to help because the motor and aluminum transom literally fell off.
