Re: towing with chevy 7.4 , 6.5 , 6.0
I hope this doesn't post twice, , almost done with my reply, accidentally hit some button and it dissappeared.
Any way, I have a 02 GMC 1500HD Crew Cab with the 6.0L. Basically it's a 3/4 ton rebaged as a 1500. Unloaded on a good day I've gotten 13.75, pulling my 26 foot enclosed snowmobile trailer out west with 4 sleds in it, basically about 6000 lbs I get 6.5 and can't find a gas station fast enough. She really pulls well though, , not sure if I'd want the 6.0 in a one ton dually, even the Duramaxes lose mileage when fitted into a 1 ton dually.
Well, everything I've read and heard says to run away from the 6.5L, they may get ok mileage empty but once you load em up about all they do is make a lot of noise and smoke, , they are not heavy haulers. Then there's the reliability factor.....
What I here around the campgrounds and from the snowmobile guys, if you want a diesel, the best bang for your buck will be a 2000-20003 Ford Power Stroke. Gobs of power (for that era) and super reliable, Xs 2 for the Dodge with the Cummins. The Durmax in that era was super quiet, powerfull but they had a bad time with injectors. Typical repair bills run 3-5K for a set of injectors. BUT, any and all diesels save the 6.5L will cost you a bunch extra initially, then there's the extra costs associated with maintenance.
Check out these two web sites; GM-Truck.com do a search for 6.5L diesel. Then go to it's either 62,65 Diesel Page.com or just Diesel Page .com. You'll get some info but if you really want all the good stuff I think you have to buy a subscription. Any way it's a very comprehensive web site about all things GM diesel.
Have you thought of a GM 1 ton dually with the 8.1L (496 cui) big block? Literally almost the same power as the Duramax, fuel mileage will be about the same as a 454 but with more power. If you play your cards right you could get a 1 ton dually, 8.1L with an Allison tranny, , that my friend would be winner winner chicken dinner.
