Tracker Grizzly 2072 L jon boat
jch7450
Re: Tracker Grizzly 2072 L jon boat
Hmmmmmmmm seems a little underpowerd, i would go out to far
Terry Olson
What is the boat's max horsepower rating? I don't think 9.9 is even half of what you'd need to plane it out with a couple of guys and fishing gear. Maybe, since it's a jon boat. I'd think you'll want at least 50hp.<br /><br />My second boat - soon to be someone else's - is a 14' tri-hull made of foam with an inner and outer "plastic" hulls with an older 15 h.p. outbaord. It's a cheap Boston Whaler knock off. It's very light and being a tri-hull it planes out better than it might if it were a v-hull. It will plane out loaded with two adults, two kids, and fishing gear - but the hull doesn't weigh 200 pounds I bet. Your Johnny is 6 feet longer and heavier for sure (and a much better boat no doubt). <br /><br />I checked the Tracker website and your hull alone weighs 725 pounds - not counting gear, motor, fuel, people etc. The max horsepower is listed as 90!!! <br /><br />Sure, the 9.9 will putter along but I'd think a guy wanting a 20' boat would want to get out and cover some water with it.
TTipsword
Don't' do it!!! I bought an expensive new Honda 99., 4stroke- for my 1548 G3 (a 15' welded, Mod Vbow- Jon Boat). I just gave the motor to my dad and am awaiting my new Nissan 18 HP. A 2500$ mistake. The 99. was too small for a 15' jon - I can only imagine how poorly it would work on your 20 barge. Good Luck!
rottenray6402
Ensign
If you ever boat in any kind of current the 9.9 would probably be barely able to counter the current. If it is rated for 90 I would put at least a 50 on it. They have some really good deals here on IBoats for used or reman engines. Like TTips said " it was a $2500.00 mistake". :'(
Bob_VT
Re: Tracker Grizzly 2072 L Jon boat
Yes but only as a kicker or for trolling. I would not rely on it as primary power.
