chaoticbaits
- May 10, 2011
- 2
Hi,
I have been on this site many times and gained a wealth of knowledge when it comes to boating topics...But I am stuck I have a 2000 tracker targa 175 with a 1999 mercury 125 hp elpto and i can not get it to ride smooth. I've added a manual jack plate 6" set back with 6" of travel. Current prop is a stainless lazer II 22" pitch running 5200-5400 RPM at 40-42 mph but steering torque is ridiculous it will run good with the wind or until i cross a wake or in more then 6" of chop then it will start hopping hard.i've tried moving weight around with no noticeable change. I've rewired the boat and moved 2 of the three batteries forward in the boat no change. The boat has heavy steering torque and will not reach top speed without proposing. I've tried different motor heights without improvement the best i seen was motor anti cav plate 3.5" above keel but motor would cavitate when trimmed not reaching over 30 mph.any lower i get the steering torque and porpoising.I have tried a few different props and the best was a 19 pitch aluminum quicksilver it gave the boat a good hole shot and held the bow up much better before proposing getting 33 mph at 5400 rpm but i am only at 3/4 throttle and it is way to easy to push it just a tad to far and bounce it to 6000 rpm. my most recent addition was smart tabs this helped to get the boat on plane but did nothing for the purposing problem. with the 19 pitch prop and smart tabs at the highest setting the boat ran smooth until i crossed a wake or was running against the wind then bounce bounce.I have tried different motor heights different props added the jack plate added the tabs moved weight around checked the hull for cupping and its straight. Im at my witts end the boat is rated for 125 horse is it just too much motor??? Another issue when i had all 3 batteries in the back and stood on back platform water would come in through splashwell drains that is what prompted me to move batteries forward. i have even gone to the extent of unhooking front two trolling batteries (24 volt) and trying them in different positions in the boat and i cant seem to find a happy medium. I want the boat to run smooth so my wife can drive it from time to time but with the steering torque and proposing its just not possible.Please any help would be great im over $10,000 into a boat i am not happy with and that my whole family cant use.
Thanks in advance
Dan.
Thanks in advance
Dan.
