Tracking down the right head gasket set for a 4.3 Vortec
Stamey
I have a 1996 Merc 4.3, Engine SN: 0F821477. I believe I have a balance shaft, according to the Mercruiser parts web site.
http://www.mercruiserparts.com/Show...37&bnbr=160&bdesc=CYLINDER+BLOCK+AND+CAMSHAFT
I am trying to find the correct part number for a Fel Pro Marine Head gasket set. All I have found so far is 17211 (w/balance shaft), but it seems that the intake gaskets are 12 bolt, not 8 bolt like my Vortec heads require. Looking on the Felpro web site e-catalog has given me the PN above, but I can't seem to find a PN for a set with the 8-bolt intake gaskets. (I won't know if I have the balance shaft until tomorrow, when I pop the heads off)
I'm sure someone else has been through this, and hopefully can tell me what to get. As you can see, I prefer Felpro, but if they don't offer it, I'm agreeable to another brand of high quality gaskets.
Thanks,
Chris
cr2k
Re: Tracking down the right head gasket set for a 4.3 Vortec
My book (NAPA MARINE) shows only one head gasket for the GM 262 CID - 4.3L V-6. 18-3879 Napa/Sierra Supply number. Replaces 27-11986 and 27-816460.
Same number 18-3879 shows up under OMC also. Replacing 3854299, 912227 and 914930.
Me is guessing there is one gasket out there for both 8 and 12 bolts applications.
Stamey
Yes, the head gasket is the same. The intake gaskets are different, and the head gasket sets (all the gaskets needed for doing a head rebuild) I have found are for the intakes with 12 bolts (non-Vortec). I have a Vortec engine which has 8 bolts in the intake. I am trying to find the head gasket set with the correct intake gaskets in it.
Thanks,
Chris
Moose truck
It may be faster to order the 18-3879 it and the gasket set for your 8-bolt intake manifold if you need to "Git-R-Done". Regards, Moose
Thanks,
Chris
Ayuh,... I spent abit of time lookin' this mornin',...
I didn't find 'em in a "Set" either, but available enough, by themselves....
Might wanta go with Moose Truck's idea...
Stamey
Pulled the heads, I do have a balance shaft. No obvious reason for number 4 intake valve to be leaking, but it does leak. May see if I can pop the keepers off today and see what's under that valve.
Still no luck hunting down Felpro gasket set. May have to get Felpro car set and the marine head gaskets separately.
Thanks,
Chris
Pete104
Alrighty, then!
Stamey
Sorry, didn't see the other replies before I added mine. Still had the web page up and just added another reply.
That's what I may end up needing to do, go with separate gaskets. The machine shop will probably supply the valve seals, so I just have to source head, intake, rocker cover, and exhaust manifold gaskets.
Thanks for the numbers for the head and intake gaskets.
Chris
Volphin
Chris
Try Amazon. I always get good pricing there for Felpro gaskets, and they oftentimes ship for free. :)
V
