Trade fresh water cooling system from one boat to another
hz
I have 2 boats at this time.
1) 1969 22 ft Reinell with fresh water cooling which I will be selling or parting out. The OMC 350 engine runs and the OMC stringer outdrive works too. It has no top and the condition is no where near the condition of the other boat.
2) 1976 Bayliner Skagit 2250 with raw water cooling, a rebuilt 350 Chevy engine, a Volvo 280 outdrive, a hardtop and recent paint.
My question is in regard to the fresh water cooling system on the Reinell.
1) Should I just leave it be if I sell the Reinell?
2) Can I, or should I take the fresh water cooling system out of the Reinell and put it in the Bayliner? I boat mostly on the Columbia River but will take it to salt water occasionally.
3) If I part out the Reinell, which would bring more dollars than selling the whole boat, is the fresh water cooling system worth anything?
Your thoughts on this would be greatly appreciated.
Harris
LAC_STS
Master Chief Petty Officer
Re: Trade fresh water cooling system from one boat to another
Your not supposed to put a FWC kit on an engine unless it's new. Some say after 100 hours.
Ayuh,... If yer Handy enough,...
Swappin' over the freshwater cooling shouldn't be too awlful tough...
As for getting rid of the other barge,...
The Smaller the pieces you sell,... The Bigger the final Dollars will be....
In other words,...
The Whole barge is worth Maybe $100....
Selling it piece by piece, could easily net you several Thousand Dollars....
zbnutcase
I have installed many,many FWC kits on WELL used engines and have never had a single problem. Not one. I would put the FWC on the newer boat and part the old one out.
